89 turbo dd
BoostCreep89
this is my daily driver 89 turbo 2.3l spray bombed!!
thankyou... its been a pita and the valvecover gasket likes to allow oil to be blown and great lengths under boost!!!:icon_hornsup:
Sounds like boost is getting past the rings and pressuring the crank case and the oil gallies. Is it a stock pcv setup? Or how is it routed?
well i hear this whistle/chirping sound under boost which i assume is the pcv failing... all a pcv is is a one way valve right... ive had both them off and neither hold when pressure is applied..... as far as being stock pcv system i dont know.... thanks
yup
it was the pcv valve.... all good in the neighborhood
