4EyedTurd
Lets start with that I picked up this ranger that had been sitting for a few years and from everything I've seen it appears to be just an unmolested 2.3 5spd truck.
Here is a list of things that I've done
New plugs and wires
New fuel pump, filter, and fresh gas
Used dis module (had it tested, good)
tried 2 different ecms
reset cam timing
Things that I've found
starts on its own but runs rough, barely moves under its own power
tach doesn't work/ seems like none of the gauges work
tried pulling codes but the code reader just beeps and never gives codes
I'm stumped cause I've never messed with a dis car/truck and the fact that I can't pull codes and I've tried a few different ecms with no luck.
I'm lost, can you guys help?
New plugs and wires
reset cam timing
