seth959ci
- Feb 21, 2012
any thoughts/suggestions? i have a 1/8" thick piece of aluminum that the ICM is going to use as a heat sink. was thinking about using that big bolt that joins the two bars that run from the alternator--intake manifold and then use wire or something to help stabilize. Also considering shielding to protect from debris. i can also mount a pc cooling fan if needed or run ducting from the bumper. Also will be running wires from each bolt to use as grounds
The reason for this is that the bottom left bolt broke off into the intake mani and it is frozen in there. Any help is appreciated especially creative ideas!
