89,loses power past 3000 rpm
bajascott
new fuel pump,new pressure regulator.new coolant temp sensor,timing is dead on,plugs good,wires new.yadayada
pops through the intake and has no power above 3000 rpm.
took to a mechanic and he said the cam was flat.
I honestly don't buy it....but what do I know.
I bought truck a while back from a kid that said it had a vacuum leak and that was why it ran like crap. I drove it, it had all the symtems of a bad fuel system, so I replace the above parts, it ran a little better, but it still has these problems. I have check vacuum leaks all over the intake and there are none.
I have not checked vac pressure yet, I really don't think that's a problem.
everything that is vacuum operated works like it should.
any suggestions?
it idles great,starts right up
Limited RPM can be partially blocked exhaust, back pressure builds up and engine can't pull in new air/fuel mix so power starts to drop off.
If you have a vacuum gauge($25 and very good tool to have) hook it up and run engine up to 2,000rpm and hold it there, if vacuum starts to drop you have a restriction.
Coil can't recover fast enough at high rpms so spark is limited at higher rpms
Spark plugs are gaped to wide, smaller gaps are better for high rpm power, wider gaps for low rpm power.
Another Vacuum gauge test is for weak valve springs, hold engine at steady 3,000rpm
If gauge is fluctuating rapidly then that's the probable cause
If it starts to drop then restricted exhaust.
Good read here on why you should have a vacuum gauge : http://www.gregsengine.com/using-a-vacuum-gauge.html
Didn't see fuel filter on the list of parts replaced. Partially blocked fuel filter would cause all of these symptoms.
