jmaynard
- Apr 26, 2010
- Automatic
I'm driving an '89 Bronco II XLT I bought out of a guy's barn, where it sat for over a year, for $125. I've put about $1200 of repairs into it, mainly replacing all the fluids and rebuilding the brake system. It's running fairly well now - except that the mixture is quite rich. It's pumping a lot of unburned gas out the exhaust, and as you might expect, gas mileage sucks.
I found and fixed one vacuum leak (the vacuum delay valve in the line going to the cruise control servo was bad and leaking), and can't find any other signs of a vacuum leak. Spraying the vacuum lines with carburetor cleaner made no difference in engine operation, as you would expect with a vacuum leak.
I'd cut the vacuum hose before the failed valve, folded it over, and tie-wrapped it closed. When I pulled that hose off of the intake manifold fitting, I got a dribble of gasoline out of it, which suggests that there's too much fuel being fed to the throttle body injector.
Where do I start? I've got a 1500-mile trip planned for this weekend, and would really like to have the truck running as well as could be expected for one of its age and mileage (203K) before I go...
