97fordrunner
Hey guys well now that its cold I am having some more issues with the BII. This fall it was hard to start after it had sat over night or longer I usually had to cycle the key on and off about 5 times and then it would fire right up, now that it is averaging 0 at night in the am I have to cycle it about 10 times to get it to fire but it doens't start it does the one or two cyl. fire and dies. Then I have to cycle it another 10 times and it does the same and once more cycle 10 times and it will start up and run great. Truck has two fuel pumps, I don't think the frame mounted pump is stock. I was wondering if the fuel pressure regulator is supposed to be holding the pressure in the rail and its allowing fuel to bleed back.
