Its been months since the old B2 demanded a repair. Jumped in the other day and the ABS light stayed on as did the "brake" light. Fluid level is good. The emergency brake switch works. Brakes work fine. If it was just the ABS light I wouldn't be concerned. I pulled out the factory manual and looked up the ABS diagnosis page. Wow, that's some chart! Until I have time to analyze it, is there a common failure that my dash lights indicate? A search found many posts, but most on newer 4 wheel ABS. I did find one from 2010 that might help.
