Others probably know this stuff off the top of their head, But I would have to check the door tag and then look up the code in the tech library. You can also find a tag on the axle that will tell you the ratio. There is a way of jacking up the axle and counting rotations, but I'm unsure of the procedure.
Update; read in a post by [ i think ] 4x4junkie; jack up one tire, rotate tire two times and count revolutions of driveshaft. Four and a bit rotations = 4.10 gears
Well its a 41 10 ring and pinion, which is 4.10:1. But i thought i checked my axle code before and it said 3.55:1.. I think my dad said he cleaned up my axle tag and it says 4.10. I am more interested specifically i guess if they came with 4.10's
For
