89 4x4 gears
Mikel89us
What axle ratio would an 89 4x4 4 cyl long bed come with?
Others probably know this stuff off the top of their head, But I would have to check the door tag and then look up the code in the tech library. You can also find a tag on the axle that will tell you the ratio. There is a way of jacking up the axle and counting rotations, but I'm unsure of the procedure.
Update; read in a post by [ i think ] 4x4junkie; jack up one tire, rotate tire two times and count revolutions of driveshaft. Four and a bit rotations = 4.10 gears
Richard
Well its a 41 10 ring and pinion, which is 4.10:1. But i thought i checked my axle code before and it said 3.55:1.. I think my dad said he cleaned up my axle tag and it says 4.10. I am more interested specifically i guess if they came with 4.10's
yep, 4x4 2.3L Rangers came with 4.10 gears, at least most of them did, unless they were custom ordered with something different.
wow, my dads older one has 3.73's, i figured they would have been 3.55's. oh well, i was wrong.
3.55 in a 4-cyl? No way man. That thing would suck.
Postin' from teh Galaxy
