michaelburns24
- Jul 29, 2008
- Age
- 47
Ok,
still working on my 1989 ford ranger extended cab 2wd.
Started off with broken valve spring and cracked head. Ran on but was noisy.
Replaced both heads, new bolts etc. Found a good deal on fuel injectors so replaced them since they were off. New cap/rotor/plugs/wires, new thermostat, air filter, new fluids etc.
Got engine all put together, did not have a timing light so my cousin who is a backyard mechanic, timed it by ear. Truck had all kinds of power but was making a knocking noise. He was unsure what the noise was.
I had a mobile mechanic come out and adjust the timing with a light. He timed it to 10 degrees before top dead center. Truck sounded good, and all knocks went away. However I went to take truck to emissions, and it had no power seemed like it was missing. Bought engine tester, and it said that it was running lean and to check oxygen sensor. Replaced oxygen sensor, truck still has no power. I took it to a local shop, they rechecked the timing and the timing mark was jumping around. Shop said that it probably need a new timing chain. I had a mobile mechanic come out, cuz I could not afford the shop. He took it all apart, but could not get the torx screw off of the top timing gear, he inspected the timing chain and said that it was in good condition and that there was no play in chain and no way it could have jumped a tooth. He said I should take the new chain back because I did not need it. He put it all back together. And now the truck will only run for a short time and then dies. The mobile mech said it sounded like it was out of fuel, I assured him there was plenty of fuel. He checked the fuel rail and said it had fuel. Then we started the truck again but it just keeps dying. He took out the distributor and moved it saying it may have been off a tooth. Still truck starts up, has the knocking noise again and it wont stay running. He had no clue what the problem was.
I talked to a few people, 2 said they still think the timing chain should be replaced, do to the timing mark jumping around, 1 said that the coil, or distributor may be bad, and another friend suggested that it could have a bad camshaft position sensor. I looked up that part in the chilton manual and it does not show anything for a 2.9 liter engine. I checked with autozone.com and they do not carry a camshaft position sensor, so I am thinking maybe my truck does not have one???
Anyway if anyone has any ideas I am all ears. I have been thru several mobile mechanics, and can not afford to keep dumping money into this truck
thanks mike
thanks mike
