89' 2.9 v6 with no power!
Amiddleton
Hello all,
I recently put a 2.9 V6 into my bronco ii, from a wrecked one. It has been progressivly losing power to the point that it will barely do 60mph, and the tranny jumps all over the place? Could I have hooked up something wrong? I have replaced the fuel pump and ingnition system... please help.. thanks
Dirty fuel line filter will slow you down.
Compression getting low will also, either from rings or valves although these are not usually abrupt power losses, also timing chain skipping a tooth or two would cause a lack of power in a hurry.
