'89 2.3 Missing
Crick07
The other day I was driving down the road on a long, flat section and all of a sudden my truck started missing out of the blue. Ever since it started missing it hasn't stopped. The truck is an '89 Ranger, 2.3l, 5 spd. The plugs and wires were replaced last year along with the timing belt and fuel pump. It has been running great since then until now. I thought maybe it might be a clogged fuel filter so I replaced that but it didn't help. Also, it doesn't miss all the time. It doesn't miss when its idling or if you are going down the road while it is missing and slowly release the gas pedal it reaches a point while you are letting the pedal up where it will even out. It definitely seems like it is an "under load missing" scenario. Also, the Check Engine Light is not on. Where should I start looking?
Thanks!
