have an '89 Ranger with 223K on it, and maybe 100K less on the motor. Its new to me, and I've posted before on this topic, and some suggested that the Idle Air Bypass is involved. I haven't had time to take it off and check it out yet, but certainly will.
I went to pick it up after inheriting it, and drove it back home, over 1000 miles. It seemed to run fine the night before leaving, but on the way back I noticed that it started idling funny. Down to 500, on the tachometer, and a real bad chug-chug-chug-chug feeling, like its about to die. my old 2.3 Turbo Thunderbird seemed to idle around 900, if I remember right.
I did get some computer codes. 13, 52, and 74. I did the codes procedure from memory, from when i used to do it on my old Turbo Coupe, so I might have missed a couple steps, and that would explain the 52, and 74?
The 13 makes some sense though, if we implicate that sensor/ switch. Especially with the below link.
http://www.thorssell.net/hbook/2digit.html
If did run though this procedure last night:
http://www.cadvision.com/blanchas/Ranger/idelspeed.html
It ended up idling pretty much the same, at around 500-550 rpm, and that real bad chug-chug-chug-chug feeling, almost like its missing on one cylinder. I ended up just moving the idle set screw to around 950-1000 to keep it smooth. After the drive to work this morning, the computer 'learned' again, and its idling at the same old 500-550 again.
It does have brand new spark plugs, and wires on it.
I check the vacuum and it seems fine, at around 18" mercury. if I pull on of the lines on the vacuum tree, it immediately speeds up the idle.
