RobinDutch
Hello, All. I have been pulling my hair out trying to diagnose a no spark to plugs situation. I have tried everything i can think of. Any advise would be greatly appreciated as this will serve as my daily to work driver truck till I can save up for a tranny swap on my other ranger.
Truck is:
1989 Ranger 2.3 Liter 2wd with a swapped in rebuilt 2.3 l engine out of a 92 ranger about 7 years back
So.. spark to left exhaust side plugs (which are the ones that should spark when starting.
The truck had been sitting for about 2 years and so the get her going i have done the following to it.
Drained as much gas as possible pulled the fuel filter and primed out the last of what i could using the fuel pump.
Put in about 2 gallons fresh gas with a generous amount of octane booster
All new spark plugs on exhaust side ( which should fire up on starting)
New fuel filter
Fuel pump was replaced a few years back.
Verified fuel pump is working.
Have not checked fuel delivery. psi. but it is getting fuel. just no spark
Plug wires were replaced a few years back and seem fine. just no spark Disconnected battery to try to "reset" the ignition module. No difference.
I have ran diagnostic tests on the ICM/DIM module, confirmed the Crank position sensor is sending both signals properly. all the tests ran correctly.
for a complete list of tests see this link:
http://easyautodiagnostics.com/ford/ignition_module/2.3L/ignition_module_test_1.php
except did not check for TWO DEAD CYLINDER Diagnosis see test 3
So, I swapped in a used ICM/DIM Module and a used coil pack to exhaust side
Still no spark?
I am losing my mind as i pull out my hair...trying to get this to fire up everything seems fine just no spark.
Please help me. I cant get back to work, till i can get this truck running.
Thank you in advance will check back soon.
Also. Ignition module pulled and taken to Autozone for testing. 3 tests done, all came back that it was working on the origional one and a secondary replacement one
Truck is:
New fuel filter
Still no spark?
