88 ranger
Chad_Johnson
After a while of driving an the truck is warmed up it will become rough and jerk as I drive like if some were driving a standard for the first time. I need some info on what it could be
Sounds like fuel/spark issue. Tune up? What do the spark plugs look like? Look at the distributor.
What engine, trans and 4x or 2x??
Get it running and grab each of the plug wires individually. If you find a problem you will know about it.
If that test passes hop under it and unplug the O2 sensor and see if it improves. If it does you may have a bad sensor or a bad ground.
