I have a 7amp draw that I have down to the wire off the starter relay, it seems to feed the ignition key area of wiring, what is the fix? Fire problem?
thank you all!
I just replaced the key ignition module in the column and it still is drawing power at 7 amps.
Just called Merles Auto here in Tucson, a bad Diode in the alt. might be the culprit, I will see and tell you all.
thank you all!
