red88ranger
- Apr 11, 2009
All three of my trucks are currently out of order, my 66' f100 is still in a million peices in the garage (havent had any time to work on it in about three weeks ), the f250 is overheating and need a new water pump, and the ranger has no spark.......
For the last couple of weeks i have been working on replacing the rear main seal in the ranger. Took the transmission, clutch and flywheel out, replaced the seal and put it all back together. I took this time to also replace the plugs and wires. BEFORE i took it appart it ran fine, aside from the oil waterfall comming from the bottom of the truck. Once it was all together i rolled it off the ramps and tried to turn it over, no luck, so i put a screw driver across the starter selinoid and deturmaned that it was bad, replaced it now it turns over. I crank it over and it does not fire, i smell gas and there is alittle on #1 plug so its getting fuel. i pull #1 spark plug to see if it is sparking, no dice, so i start to check electrical connections and as far as i can tell nothing is unplugged, next i replace the coil and still nothing..........
HELP!!! This ranger is kicking my a$$.
