1988B2
- Oct 30, 2015
- Automatic
88 bronco ii 2.9 auto trans, will cranK up fine after has been sitting all night. If. You let It idle it seems to flood the engine with fuel until it dies. Then it is very hard to start back up lots of cranking the engine over and very lightly patting the gas unit it eventually seems to fire and crank. Then you can again feather the gas and keep it running but if you give it any more throttle than maybe 1/8 it will stall and die. I have replaced both pumps bypassed the plastic fuel housing new filter. Cleaned iac, fuel pressure regulator (checked fuel pressure) new plugs checked wires cap and rotor button,new Map sensor,tfi module on distributor , new coil, cleaned throttle body and may be missing some I also tried unplugging the o2 sensor I read it would tell me if need to be changed but am at a loss and this is my dd and only ride lol.
