Smellslike1974
- Mar 21, 2013
- Automatic
Hello,hopefully you guys can help me out with this! This has been an ongoing problem and has sort of been in stages.
The problem that I first started having was this: My bronco would start,idle,warm up normally. Then after driving for a while, if I stopped and turned it off. When I go to start it back up,it doesn't want to idle and if I don't give it gas it will just shut down. I end up having to keep it at 1,000 rpm to shift or it will cut,this means riding the brake which I hate doing.
I tried fixing the problem on my own thinking it was ignition:
-New Spark Plugs
-New Spark plug wires
-New distributor rotor
-New Distributor Cap
After that the stalling problem still existed but it ran way better(it needed all of that!) Eventually after a while though the bronco just stopped starting completely. On my way home one day it bogged and died, wouldnt start back up...
Then I leaned towards it being a fuel issue:
-New fuel pump/sending unit in tank
-New fuel filter(one closest to engine)
This is where I am stumped guys... The bronco will start/run and drive but I am still having the issue of it stalling when I go to start it again after the initial start and drive. Obviously everything I have put into it,it definetly needed but I am confused on what it could possibly be. Sometimes,and when i say sometimes i mean rarely it will start and idle by itself when starting after driving it,but when it idles it fluctuates high and low almost tripping on itself like its about to stall but comes back to normal.
I have read from multiple sources that the bronco has 2 fuel pumps and two fuel filters. An internal pump which is in the tank and an external which is mounted on the chassie. I have also read that the internal pump pumps fuel to a filter then to the engine,and also theres a second line connected to the external pump which connects to the second filter then to the engine. Can anyone clarify this? Maybe a diagram? Whether or not its the problem I would like to put on the second filter and see if the external pump is working correctly. Underneath the driveside is the second fuel filter hugged by a removable frame peice. Maybe 2 feet towards the back of the truck is a vertical looks canister Is this the external fuel pump?If not does this get clogged,Is it even important!?
I thought maybe it was a vacumn leak also but cannot find whats leaking if so.
Any questions please ask!
-New Spark Plugs
