Diggerauditor
I did a V-8 swap into my 88 2WD last year with a 97 exploder motor and accessory setup. I want to convert to a ranger or saginaw PS pump, because the exploder unit will not drive my truck with 4" lift and 235 tires. Is there a bracket that I can use and still maintain current accessory brackets or will I need to change the whole drive belt setup. If so what bracket do I use or where do I get one. The wrecking yard here has plenty of items to choose from and I will be going out this weekend to search it out. Any help would be appreciated. Thank you
