Screech1
- Apr 9, 2011
- Age
- 39
- Northumberland PA
- 1990, and 1988
Hey guys I was here before and I told you guys I bought this truck well I'm having problems getting it to run right. So far I replaced the distributor cap, new plugs and wires TPS IAC sensors but still the same. If you start it, it idles but sounds like it is cammed up, but idles. I set the timing and still the same, when I did that I was playing with the throttle and when you open it wide open it sounds muffled it wont idle all the way, but when you let off it revs real high and then shuts off, but will fire back up with the same results. I'm really at my wits end on this, don't really know where else to turn, so here I am. Any Ideas would be greatly appreciated. As always THANKS ALOT
