87 turbo ranger
did that come with manual brakes stock im doing a v8 swap and i want to convert to manual
ok i take back what i said...do to financial reasons....im parting it out...or someone can buy the whole truck for 2500...theres a lot of parts in this thing
What about the dash? Lol if your parting it out.
so i was slightly bi polar about what i was going to do with this truck. well i was offered a ranger that had a good cab for 100 bucks so i have been rebuilding it, just haven't really posted anything so expect a huge turbo ranger take 2 thread to be started up, ill post a teaser though. whole truck is 2 inches lower then before, will be satin black, on black crawler rims with a burnt copper accent color. heres what the "new" engine bay looks like as of tonight.
its not done I'm still cleaning up the wiring
87 turbo ranger
how wide do you have the tires for the cobra rims? and do you know how wide a stock ranger can handle on the front?
glad your fixing her up!
new updates coming soon....long story short, black ice+40mph+turbo spooling=upside down in ditch in december at 1am....but the rebuild is almost done....satin black, 3 inch pulled bedsides, 15x10s in the rear with 6 inch dish, new fuel system, 42lb injectors and a standalone....should be 300+rwhp and the goal is to have it at stancewars on july 7th...anyone wanna help make sure i make it there? heres a teaser of the engine.
87 turbo ranger
87 turbo ranger
87 turbo ranger
87 turbo ranger
87 turbo ranger
finally got my PiMP!
Just studying everything and becoming familiar with it before i put it in!
Features/Capabilities:
-VE Analyze Live "Auto Tune" (More Info)
-Ignition Spark Control
-Fuel Control
-Idle Control
-Table Switching
-Electronic Boost Control
-Rev Limiter Control
-Launch Control (2-Step)
-Flat-Shift (Maintains boost between shifts)
-Two Stage Cooling Fan Control
-Nitrous Control
-Supports Low Impedance 4 Cyl Injector Control
-Supports High Impedance Injector Control
-4 Bar (44psi) Internal Map Sensor
-Full Datalogging
-DB-25 Internal Expansion Connector
-and many other features and capabilities...
Includes:
-PiMP ECU
-1GB USB Flash Drive (containing all required software, startup instructions, base tune, etc)
-Licensed TunerStudioMS Tuning Software ($69.95 value) (More Info)
-MegaLogViewer Datalogging Software (More Info)
-Serial Communication Cable (Serial RS-232)
-Silicone Vacuum Hose with zip ties
-PiMP Engine Management Sticker
-Startup Guide
-Software Setup Guide
-Online Technical Support Forum
-Online Tuning Guides
-Online Tutorials
87 turbo ranger
87 turbo ranger
87 turbo ranger
anyone on here good at tuning megasquirt systems? i need a hand getting this thing tuned this week so i can make it up to stance wars
heres some more photos of the progress
87 turbo ranger
87 turbo ranger
87 turbo ranger
87 turbo ranger
87 turbo ranger
87 turbo ranger
87 turbo ranger
87 turbo ranger
sanding and prep for a fresh paint job...satin black!
87 turbo ranger
87 turbo ranger
she has glass!!!! and a bit of paint. satin black and burnt copper accent
87 turbo ranger
87 turbo ranger
87 turbo ranger
87 turbo ranger
87 turbo ranger
87 turbo ranger
so did you swap cab or replace the roof?
umm put simply i did a body/cab swap with a bunch of other work...tore the truck down to a bare frame and rebuilt
