Aadams_4440
I have a 87 that the touch drive system was taken out. Has anyone bypassed the module and built switches to engage the 4wd low and high ?
It has been done. I don't think there is a tech article about it. But if you search the forum, there are threads with people talking about doing it. If I recall, stopping the motor at the right time is tricky. It might be easier to find parts to reinstall/rebuild your touch drive system.
If I remember correctly the 87 bronco II have a abs module and not a 4wd module.The system is made up of 3 basic parts. The pushbuttons where you select 2-hi, 4-hi and 4-lo. An electronic control module, often found behind the driver seat in a Ranger. And the shift motor at the transfer case. The shift motor has a little wormgear box on ot that also contains some electrical contacts that tell the controller what position the transfer case us in. Here is a good place to begin troubleshooting and figuring out what components are working, not working or missing. In many cases, the contacts at the shift motor ate dirty or corroded from not being used often enough.
Ford Ranger 4x4 Module Diagnosis (1994 & Older) - The Ranger Station
By Chris1044 If your 4WD Ranger has a push button 4wd system (automatic, no manual lever), than it’s going to have a 4WD Shift Module mounted somewhere in the cab. The photo above shows one mounted under the jumpseat … Continuedwww.therangerstation.com
ABS has nothing to do with your 4x4 system. If you have an electric shift transfer case, it has a control module. On much, much newer trucks, it is built into the GEM or something like that. But on a 87, it's a separate module.If I remember correctly the 87 bronco II have a abs module and not a 4wd module.
Any idea where it’s located in a 87? 88 plus it’s where the abs module is on my 87.ABS has nothing to do with your 4x4 system. If you have an electric shift transfer case, it has a control module. On much, much newer trucks, it is built into the GEM or something like that. But on a 87, it's a separate module.
