leftlane
I know that the 87 has a larger throttle body than the 89 has I just need to know if it is a direct bolt on swap. I just encountered the notorious 2.9 head problem and found a replacement from a 89 Bronco II. The bronco motor runs smooth and has no lifter tick and is completely dry, NO OIL LEAKS. Will there be any advantage to swapping the throttle body. Thank you
