nucleardog
- May 7, 2009
- Automatic
So the stock tach doesn't work, stuck at around 3k RPM. If you give it gas though it starts to read, but once you let off, it stays where it peaked. So what gives the signal VSS? or what do I need to replace? Also the odometer doesn't work, though the trip odometer does. Are the odometer/tach issues related? Thanks in advance!
