- Nov 6, 2011
- Automatic
Just wanted to put a thread together for our ranger build.
My dad and I just picked up a 87 Ford Ranger, 2wd, Reg cab, with a long bed.
Our plans are to build a drag race truck out of it.
So far we have decided to build a 347, C4 Trans, and a 8.8 rear.
Im still trying to figure out what rear housing to get. We picked up a 8.8 housing from a 99 ranger from a friend of mine. I have been reading here and online about swapping in a housing from a explorer.
We went to our local junk yard and looked at a few explorers trying to figure out if they had any available.
We found a 97 explorer that had the springs on top of the rear just like in a ranger, the rest of the explorers had the leafs under the axel.
The motor as mentioned will be a 347, we will be using a stock ford h.o roller block. We will be going carb for ease of install, I picked up a victor jr intake today for it. As far as a carb, we will more then likely be going with a quick fuel 750cfm carb. The heads we plan on using will be Trick Flow Twisted Wedge Aluminum, with 1.6RRs. The cam im thinking about going custom, but if we dont go custom we may end up going with a TFS STG 3 cam or something similar. Crank will be a Scat, Rods will be eagle H beams, and pistons will be Ross TW specific.
The motor will be built by my engine builder, he is a local guy.
Trans will be a C4 as mentioned above. It will be built by a local trans shop.... Reverse Manual Valve Body, JW steel bellhousing, Race Clutches, Race Bands, deep pan, Servo, and roller planets. We will be trying a 3,500 RPM stall at first to see how it works, may end up going higher later.
The rear as mentioned, we are going to go with a 8.8 out of a explorer, that way we can use the 31 spline axels, and rebuild stock T Loc. I ordered a set of 4.30 gears, they should be coming in soon.
I'll try and get some pics of the truck soon, and Ill try and post some pics as the build goes on.
