'86 Turbo Diesel Build
I am me
1986 Ford Range
I'm getting a 1986 4wd Ranger (just got to tow it home now) and I'm planning on sticking a Mercedes OM617 engine in it. I might use a vw TDI engine instead but I really don't want to mess with all the electronics that go along with the vw engine. Called a couple junk yards today to see if they've got the Mercedes engine I want, hopefully they do.
The shifter is prity slopy so probably just worn out bushings. Think this'd fix it?http://www.partsgeek.com/gbproducts/DC/5511-05308635.html?utm_content=DN&utm_term=1983-2011+Ford+Ranger+Manual+Trans+Shifter+Repair+Kit+Dorman+83-11+Ford+Manual+Trans+Shifter+Repair+Kit+1996+1995&utm_source=google&utm_medium=ff&utm_campaign=PartsGeek+Google+Base&gclid=CjwKEAjwp-S6BRDj4Z7z2IWUhG8SJAAbqbF3aqPlX19EmHDbH644X2QGeR_9bxzSqa-LJYxFkM0yYRoCOmvw_wcB&ad=47362750812
Here's what I've learned I'll need to do, feel free to add on.
Notch oil pan
Lift the truck, possible body lift
Remove the Ranger fuel pump and put a filter in place of it
Use 5/16 hydraulic line for the fuel return
Remove vapor return check valves and replace hard-line that goes to the bottom of the tank for fuel return
Possibly add a larger alternator
Use Mercedes oil cooler
Possibly need electric cooling fan
Push button for glow plug
Switch for fan if electric used
Got the truck! Going to go pick up a the Mercedes engine for it tomorrow and a new gas tank
Out with the old, in with the new! It almost looks like someone drilled holes in the old tank. Stuck a new fuel filter in to.
The shifter is really sloppy and I thought the bushing pack I linked in my first post but that's not the right one. I think it has a Mitsubishi FM145 transmission, anyone know what the right part is?
I was looking at that adapter but decided against it because of the cost of swapping the transmission. I can make an adapter so I'm just going to try and use the transmission that's already in the truck. Hopefully it'll hold up to the bigger engine
Got the engine! The guy wanted to sell all his old Mercedes stuff so I had to buy the transmission to. Bought an entire an working 300dt complete, except for the radiator, and a couple body panels. All in all it only cost me $350! Going to have to rent another trailer and bring the car home Thursday
And a pic of how nice the tires that came on my truck are
Here's the parts car. Hopefully will get the Ranger's engine out this weekend.
What is this thing? (it's in the Ranger)
Ok thanks, I couldn't tell what it was being hooked to both the windshield washer fluid and the throttle body.
So I've got a big problem, I disconnected the engine from the wiring harness and forgot to close my (power) windows. When I hooked the truck up to a battery an error light came on and nothing gets power. The Mercedes engine won't be using any of the wiring that I just undid so how can I fool the truck into thinking nothing's unplugged so that it'll be usable with the new engine?
Working on taking out the transfer case, what are these hoses? The first pic is from the front of the transfer case and it hooks to the transmission I think, the other one is on the back and I don't know where it goes
^ Never mind I got it. Couldn't get the rear driveshaft off the transfer case so it was a little annoying to remove but I got it. Got the engine and trans totaly disconnected except for the clutch line which is givinge a hard time. Hopefully the pb blaster is put on ita will have done it's magic by the time I get home from work tomorrow and I can pull everything out
lots of interest over on peach parts.:popcorn:
I'm putting an OM616 into my ranger as soon as we get snow this winter. not sure if I will buy a kit for the smallblock ford bellhousing and put in a T5 or use the stock 4spd manual and all MB parts. trying to keep mine as light as possible and 2wd for summer commuting only> occasional use by my wife to haul the monkees around:icon_thumby:
oilburners has a MB diesel section too. keep at it, its a very cool way to run a ranger!:beer:
