Picked up a 1986 Ranger with the Mitsubishi Turbo Diesel. Seller thought it might have a blown head gasket, but he isn't sure.
It was leaking from the water neck below the water pump, like gushing out. Found out the gaskets weren't available, and someone siliconed it in. Cleaned it up, made gaskets, and its fine now.
It seems like it's having a fuel starvation issue. It will run and idle good cold, and drive good in gear for about 10 seconds, then it will rev down and stall out. If you baby it along, it will continue running barely. Usually I would have to wait a few seconds, crank it over, it will slowly restart, and idle fine. And repeat.
Should I change the fuel filters and hope for the best? No oil in coolant, and no coolant in oil.
