Mike205
- Sep 12, 2016
- Automatic
Before I start here is what all has been done
-new fuel pumps and filter and fpr
-new distributor with plugs and wires and tfi module and coil
-upper and lower intake gaskets
-tps,idle air control,map,coolant temp,air inlet temp sensor and O2 sensor
-egr valve
-pcv valve and new breather
-new computer
Also used the old rubber air filter cleaner hose and put a cone filter at the end of it.
Codes while running
-12 can't control rpm during high rpm check
-23 tp sensor out of range
-24 intake air temp out of range
-42 Rich exhaust bank 1
-31 egr out of range
-13 can't control rpm during low rpm check
-25 no knock signal
Codes not running
-54 air charge temp signal high
-egr valve
-new computer
Codes while running
-25 no knock signal
Codes not running
