RangerRich
- Nov 27, 2008
- 1986 Ford Range
You guys know a lot about 2.9. can tfi go out over night and make a truck run like crap.
It run good up to 50mph then starts cut out just on power.This is after it warms up mileage has droped off from 20 to 15mpg.
try to pull the codes
I have ckecked for codes and come with nothing.I am going to replace the tfi
This all started when my fuel reg went out it had 90lbs pressure.I had ford replace the filter,reg,cap rotor wires and clean the inj.at what that cost I can replace alot of parts.I have 35lbs fuel pressure now.I have replace all the sensor and check the grounds all looks good.I think I will pull the pos.cable off
and clear the comp.at this point I will try any thing.
RangerRich.
