86 b2 with 2.5" susp. lift Will 31x 10.5 x 15 fit on stock rim?
geck0
Cincinnati
Will it fit on the rim and not rub with about 2.5 suspension lift? my rims are the later style aluminum ones with the multiple inch holes around the hub :icon_confused: (not sure of rim style name)
shouldn't rub to bad, if it does break out the sawzall.. and ditch the front sway bar.
This style rim?
This is mine back when it was stockish, 2" lift with 31 x 10.50 x 15. Only rubbed on the front swaybar.
And, just for the hell of it. This is how it sits now.:D
-Jester
yes jester that is the rim on it. so they will work then
sweet thanks guys i found a set of kumho venture mt 834's half tread for $115 locally thanks for the quick responses!
I drive mine with a 2 inch lift and 31's full tread on stock 85 b2 wheels every day with no rubbing at all.
