86 B2 radius arm bushing gone bad
the way ur passanger one is i wouldnt doubt that it ruined ur bucket cause mine was the same way, i just went ang got a new crossmember and installed it and used the old bolts off of the old bucket that hold both sides together and used thoes to mount the new buckets. sorry if thats confusing
What is this bucket yall are talking about? I know a previous post said it was reproduced by Dorman but is there a particular name for it so I know what to order if I need too?
This is what I ordered
I had previously lied... It's reproduced by Moog, not Dorman.
It's called a radius arm bracket.
Take the nut off the back of your arm, see if the arm has messed up the bracket or not. Or just put a picture up here.
Sent from my PG86100 using Tapatalk 2
so take the nut off along with the bushings? Is the bracket going to be part of the cross member?
Take the nut and the rearward bushing off. See if the arm gouged itself into the bracket.
The bracket is half the crossmember. I believe there is 4 bolts in the center, holding the left bracket to the right bracket.
...your making me think, its been years since I owned a TTB.
