junkfixr
I'm putting a cab from an 86 2WD onto an 87 4WD (good engine & trans) and now ,having everything stripped I'm noticing...
The 87 4WD has a wire going to the trans where the speedo cable installs. I'm assuming this is a speed sensor ? The 86 2WD does not have this.
Is this going to cause problems, or is there a pre-existing wire in the 86 harness that I should be looking for ? Really don't wanna change the entire wiring harness if I don't have to.
Thanx in advance,
Kevin
Thanx in advance,
Kevin
