cp2295
- Jul 25, 2013
- Washougal, wa
- My credo
- If you ain't first you're last
Hey there was out beating on the old b2 a while back and she just died on me. Replaced the ignition coil and the coil module (tfi). Still no spark so i gave up, coil has power on the red and green wires, black wire on the side of the coil has ground. Tfi module has power at 2 terminals. The ground wire (controlled by the ecu) is not grounding, i am unsure if im testing it properly, im just checking it on key on, not cranking. Power wire to the ignition coil does not pulse when cranking. If anyone has a wiring diagram that is worth a damn please post a pic! All help is greatly appreciated need to get that thing going again
Just want to make sure im not missing any simple wiring or computer issues before i go ahead and replace the distributor
