85_Ranger4x4
Wallers in rivers
💻 TRS Socials
- Aug 7, 2007
- Frankfort
- State - Country
- IA- USA
- 5.0L
- Manual
Well the old balljoint redeemed itself and earned a spot in my BJ press case. That is the way to do it.
The new shell is in.
Her birthday present was a day late but she seemed to like it.
Finally got around to putting in the rear speakers so hopefully I can hear the radio over the wind, tires and exhaust motating down the highway.
I was impressed they dimpled the cab where the brackets go.
Then things start going downhill...
The seating situation with buckets have been a constant thorn in my side since I put them in 5 years ago. I am too close to the wheel, my legs cramp, it is borderline claustraphobic to drive... just not happy with it.
Since I have a wiring problem under the dash that has been bugging me that would be easier to get at without the seats and I want to put the bench back in...
I had to remove the parking brake pedal assembly to get at it, and this is why my dome light keeps blowing the fuse. I could see the spark behind the fuse panel before the fuse popped. Kind of the funniest type of wire chase I can think of, the problem is right in front of your face when you put the fuse in the block.
The little turd didn't leave me much to work with.
How it more or less sits now.
I have a new carpet kit for it but I am waiting until I get a 5 speed in it before I install it so I only cut one set of holes in it. In the meantime with the holes in the floor more or less open with one window down I suck tons of engine heat in through in the floor which then goes past my face and out the window. This has been another thorn in my side. So my temporary solution probably isn't the greatest but I think it will work. I went and got me the tannest rug I could find which after putting it in my truck it doesn't look so tan. Oh well.
My GF found it and had it in the kitchen, I am wondering how long it will take her to notice it is gone.
I am going to tweak some other wiring stuff and then go back together with the bench.
