bobbywalter
TRS 25th Anniversary
Ugly Truck of Month
- Aug 9, 2007
- woodhaven mi
- Automatic
- Total Lift
- sawzall?
- Tire Size
- 33-44
- My credo
- it is easier to fix and understand than "her"
The thing is it would just be me pulling it. I have done everything but the pivot bolts on the axle in the truck.
I didn't want to toast the trans or turn the D28 inside out. It wouldn't even wiggle so I didn't see the point. I just walked back and got the tractor that had the boom on it (it had a snow blade on it by then though) The abs thing would work better if I could see the tires, I use that principle with the differential brakes on my tractors... and actually used it to jerk the truck out.
once you get used to it, you will know what tire is spinning and needs held without looking.
putting the solonoids on momentaries works the best with the rears isolated....just bumping the brake a bit. of course probably a horrible idea with a d28
