85 ford bronco with a 4 speed........ HELP
josh_lulu
Roseburg, Oregon
i have a 85 ford bronco 2 4x4... it orignally had a 2.8 v-6 5 speed tranny, and tranfer case... i have a 302 (carb) with a 4 speed now (435) and 205 transfer case... was wondering if anyone has does this conversion, and if so what clutch linkage did they use? pictures would b great... if need my number to text me information let me know..thank you
I've done that swap but I used a hydraulic slave for the clutch, like a stock ford setup. To simplify you can source the bell housing to use the slave cylinder, it would make things a lot easier for you. Then you can use your setup that's in your bronco already as well as clean up for exhaust routing.
