baconops89
I recently did a compression test on my engine prior to replacing valve stem seals and my readings were all around 120psi. Is this normal for the 2.8?
Oh well when I did it I had all the spark plugs in except the one with the compression tester on it obviously and I didn't have the throttle open. So if I was to do it again and pull all the plugs and open the throttle do you figure I'd get higher readings?
