Dustinicus
- Aug 21, 2013
The other day, my truck got a nasty misfire, I checked plugs coil etc... and it didnt get better. The truck died the next day, just shut off. Since I have it out of commission i decided that i would go through the entire fuel system, engine, electrical, brakes, and engine management.
I figured that since the truck seemed to have been running a while with a lean condition that I should take the head off and get a good look at what everything looks like, then i can decide whether or not im going replace the engine or just rebuild the head(unless inspection proves it to be damaged), as long as the cylinder walls look good and there isnt any excessive wear on the head, ill go though and make sure it in tip top and toss her back on.
Anyone got any suggestions about work i can do and suggestions about things to check on the head?
-Dustin
-Dustin
