chase758
I have a 85 2.3 that is poping though the air box. It is missing on no. 4 cyl. It is getting fire on the cylinder but not sure about fuel. The truck has sit for about 3 years, could it be a valve?
If its just one cylinder maybe you have a dead injector, who knowsDoes anyone have any ideas?![]()
I installed new plugs and wire,still missing. How can i check the injector?
I believe the 2.3 recived EFI in 85. So if you have a carb then he has a 2.0, if no carb then he has a 2.3have you tried this? You use a volt meter to check resistence pull plug and touch terminals. An 85 is it injected or carbed?![]()
I pulled the valve cover to discover a rocker arm off.
