84 Ranger shifter problem
pedal2themetal45
15+ Year Member
Boise Id
HI,
long time no post.. anyway
I had my truck at the shop and when I went to pick it up my floor shifter was all F'ed up. Its a 4 speed with OD.
My shifter was out of wack by 90* instead of pointing straight back (coming out of the transmission and pointing towards the seat... it was twisted and pointing toward the drivers side?????? (coming out of the transmission and going toward the drivers side.. WTF..
I went in and got the mechanic to show him and ask what happened to my shifter... He came out and said yeah I may have gotten a little rough with it.. then he grabbed the shifter at the transmission and twisted the lever back to the proper location??????
My shifter has been a little sloppy but never that bad and never moved like that ....
So my question is did he F up my shifter or is that something or how they can move...
Help..
Thanks for any response and information..
What part of your shifter rotating 90 degrees doesn't make you feel like it is screwed up?
Not sure what you want us to tell you. I think I would not be going back to that shop if they feel like this situation is OK.
I don't know why it would twist around like that. It is basically just a piece of round stock with a ball on the end and a couple pins to keep it centered. If it's anything like the Mitsubishi trans shifters, they are kinda flimsy and do wear out. I haven't seen one of those in many years though, you are probably one of like 5 people on this site still running around with a TK transmission. New shifters are not real expensive though, maybe just replace it?
HI again.
What is a good replacement transmission for the 84 2.3- 4 speed with OD.
