83 ranger upgrades
83_rangerdave
well its got the 2.8 auto with brand new tfi distributor ;( too bad isn't duraspark but does anyone know for sure wireing in a msd 6a would help it? I can get a box for 100 would it be worth it on this engine?? just which it had little more power. let me know guys asap and thank u all for help in past
replacing the cam and lifters, headers, holley or 2150 carb upgrade (if it doens't already have the 2150), and the duraspark will just about max out the mods available for your 2.8. i need to decide by next summer if i'm going that route or replace it with something that has more torque and hp.
another thing i did which helped a lot to get the most from my truck was to replace the 4spd man tranny with a 5 spd.
I want a 5spd tranny but they are out of my price range at the moment. When I was doing my v-6 swap I was going to put one in but I couldny find one so I had to settle for the bellhousing and keep my 4spd, but no plans on driving on the highway.
comp cams makes two cams i suggest the .428 lift, or do what im doing and get one custom grinded. go get a 20 dollar 4bbl to 2bbl adapter along with a 390cfm holley, along with NGK spark plugs, MSD street fighter coil, MSD 6al box, 9mm wires, make some custom underdrive pulleys somewhere around 25% or if you wanna get crazy 42%. go to a junk yard grab a turbo and oil hook ups for it weld a adapter for your exhaust manifold, tap your oil pan, and then get water/methanol injection to prevent detenation. and call it a day. put seafoam in it prior to all the suggested mods....it works.
