eightynine4x4
- Oct 15, 2020
- New York
- 2.9 V6
- Automatic
- Total Lift
- 2.5" Suspension
- Tire Size
- 31 x 10.5 x 15
Exactly
Most of the time, ignore the neutral position for the transfer case. It could be handy if you get the front and rear bound up against each other, to relieve tension. But most of the time, ignore it. Use your transmission as normal.
With an open differential, it is OK to leave the hubs locked for normal driving.
So my truck has an open differential?
And when at a stop in order to shift into 4L, should put it in Neutral with the steering column shifter? Or should it not really matter if it’s in D or N?
