Wa11banger
i have read all the tech guides and am actually using a few of them to put the rear end back together. But I am having a real hard time with pinion depth..
Unable to use original shim set up for gauging because rear end was destroyed so starting from scratch
trying to achieve the 4.420 factory ford pinion depth and unable to do so. Without any shims deepest it can go riding directly on bearing is 4.347.
I have check and ensured bearing race is fully seated.. I have ground out all the old bearings so I can facilitate faster setup and checks but cannot for the life of me get any closer to 4.420.
Is the 4.420 just a guide? If you cannot achieve it what next? Is there a possibility new bearing race is thicker than old one?
any help would be appreciated again thanks
