- May 18, 2008
- 92 & 83 project
- Automatic
A bit confused on what the proper nut torque is on a new install of the pinion bearings and the new crush sleeve. at the moment i have it tightened down to 90/lbs but I think I need to go more to fully crush the new sleeve. everything is new except the pinion gear, the ring, and the carrier.
I have read were it should go down to around 200/lbs. ?
open carrier with limited slip spider 28 spline if this makes any difference.
thanks
thanks
