Shran
Junk Collector
Solid Axle Swap
Truck of Month
I just picked up an Explorer 8.8 that is missing the ID tag. It came with a junkyard tag that says it's got 3.55 gears, but the guy I got it from says it's got 4.10s. Either way I don't care, I just wanted the housing and disk brakes, but I am curious. It's also got a limited slip, if it matters.
The ring gear is stamped with the following:
A 2 410 E7TW CB 11 39-617T
So from this I am assuming it has 4.10s. Correct? I'm not sure because my old 7.5 definitely had 3.45's, and the ring gear was stamped with something totally different.
