crx_si
I was wondering when swaping the 8.8 rear end into the ranger from the explorer could you use the existing spring pads on the axle if you wanted to mount the spring underneath the axle. The reason I ask is beacuse I have a 1994 4cyl and I want to upgrade the 7.5 to a 8.8 and I don't care if the truck is jacked up becasue it is only a 2wd street truck.
Thanks in advance Tyler
