94BonB
- Nov 2, 2009
1987
- Automatic
I got an explorer 8.8 rear end with disks and 4.10's, The problem is that the carrier was welded, this wouldn't be a problem if it was just a trail truck, but its my DD. Anyway I'm replacing the carrier and putting a lock right in it. My question is, if I pull the carrier with the ring gear but not the pinion do I have to go through all of the gear set up? like if a swap the ring gear to the new carrier can I just go a head and bolt it back in? because my pinion depth hasn't changed.
