Just_Randy
- Sep 14, 2007
With almost 200k miles on my ranger its no surprise I have play all in the axle. Play in the spider gears, lots of backlash, and the pinion seems to wobble a tiny bit. I took the diff out, grabbed the pinion gear with my hand and I can pull it in and out enough to make a knocking noise.
My question is does the pinion have a crush sleeve and can I tighten the pinion nut to crush the sleeve some more? Everything else I think I can shim up to remove play.
