My fullsize has decided that every system is going to fail one at a time until i have rebuilt it entirely. this week its running on the left bank only. Ranger44 has been a great help in narrowing things down. Right now it looks like either the under valve cover harness or the injector driver module. the harness from the idm to the uvch is good, but i'm too lazy to rip everything out of the way to get to valve cover and test the harness inside. I did run up to O'Reilly to jack their obd2 scanner. at first the truck was running normally and printed no codes at all. by chance it happened to start running like hell while i had it hooked up. it printed all of the following codes:
P005A - "B camshaft profile control performance/stuck off bank 1"
B1C2C
B31CF
P0BC4 - "hybrid battery temperature sensor "E" circuit low"
U3110
C3300
P0005 - "fuel shutoff valve "A" control circuit/open
C1300 - "ABS pump motor circuit failure
C38FF
U3F27
U05A6
U2197 - "Invalid data for vehicle speed"
I have only been able to identify 5 codes so far and most of them seem to be side effects of the engine running on 4 cylinders. If anyone can help fill in the blanks your help is greatly appreciated.
B1C2C
B31CF
U3110
C3300
C38FF
U3F27
U05A6
